This is part 2 of the “Creating a New Map Style” series of articles.
After we have decided on a style to create last month, let’s take a look at creating the first new pieces of artwork. One of the defining aspects of a style are fill styles it uses.
Let’s take a look at the bitmap fills used in the World of Wonder style, which serves as the basis for our new style. Open the CC3+ program data folder in Windows Explorer: C:\ProgramData\ProFantasy\CC3Plus and find the subfolder /Bitmaps/Tiles/Overland/Annual Worlds of Wonder/. You’ll see that it includes 9 different fills, with at four different resolutions each.
Create a new folder under /Bitmaps/Tiles/Overland/ called “Annual Worlds of Wonder BW”, then copy the VH resolution file of each fill over to the new folder. Remove the _VH part of all the file names. Now you can open up the individual files in a Bitmap editor (like Photoshop or Gimp to edit the textures. I’m doing some very simply operations here, converting the files to greyscale to match our idea of a black and white stlye, and I rotate some of them and/or apply a photo filter. Of course you can be as elaborate as you want, even creating complete new graphics, but for the purpose of this tutorial I’ll keep it simple.
Let’s get the new fills into our map template. TO do so, we need to start CC3+ and load our template /Templates/Overland Maps/Wizard/Annual Worlds of Wonder BW.FCT. The select Tools > Import bitmap fill styles from the menu.
The import bitmap fills dialog comes. “Browse” to our newly created source folder and select one of the files. Check the “Create other resolutions option and set “Scaled” to 1000.00 for both width and height. To differentiate the new bitmap fills from the old ones, change the “Suffix” to _BW (for our black and white style). Then click OK and let CC3+ do its work.
3. Changing the Existing Fills
There are only a few entities in the template that use the old (coloured) fill styles, but even if there were more, it is easy to change them:
- Right-click the Change Properties button and choose Change Fill Style.
- Right-click on the map to select, then choose More > Fill Style.
- Right-click to bring up the fill style dialog and choose “CA145_Parchment” from the Bitmap Files tab. Click Ok.
- Right-click and choose Do It.
- Right-click to bring up the fill style dialog again and choose “CA145_Parchment_BW”. Click Ok.
You’ll see that the parchment border of the map has turned grey. You can now do the same for each of the existing fill styles, but for this map you really only need to do it for the CA145_Ocean fill, as that is the fill of the background rectangle.
The template now shows a greyscale version of the old one and that’s how we wanted it to be. Next time we’ll start of converting the symbols of the style into the new look.
Nice work, Ralf – looking forward to the next instalment 🙂
