The June Annual is not the only new download available now from your registration page – you can also download the Random City command by Lee Saunders for CC3+ from the same place. Coincidence? Hardly!
For the Annual we’ve created a lengthy tutorial on how to use the Random City command and what to do to customize and enhance the maps the command creates for you. That way you can quickly create a base map and continue to map the city after that as far as you like.
The Random City command was originally created for use with City Designer 3 and is listed separately under CD3’s downloads. But it is also included in the June Annual download, and if you do not own CD3, you can use it with the basic city style in CC3+.
In addition to the Random City command itself, the June Annual contains a 9-page tutorial and 2 example maps created with the command, one done with City Designer 3, the other with CC3+ alone.
The issue is now available for CC3+ from the registration page for all subscribers. If you haven’t subscribed to the Annual 2017 yet, you can do so here.
