We are happy to announce a new version of Fractal Terrains: Fractal Terrains 3+.
Joe Slayton has been hard at work to update Fractal Terrains with a 64-bit core, greatly improving the speed and editing detail of his world building tool, while also adding more functionality and ironing out various kinks. This version is a free upgrade to Fractal Terrains and available from your registration page among the other Fractal Terrains 3 downloads. As it is a 64-bit software and uses a different setup architecture from FT3, it is a complete new install, meaning you can install it in addition to FT3 and uninstall that older version at your leisure.
Here are the release notes on 3.5.1, the version number of Fractal Terrains 3+:
FT3+ Verion 3.5.1
– Includes “The One-Day Worldbuilder” Annual issue by Sue Daniel (CC3+ required).
– Added export settings for common CC+3 styles (Mike Schley, Jon Roberts, Herwin Wielink).
– Added FT3-style CC3+ export setting “Jherion”
– Fixed river generation.
– Fixed CC3+ export settings save.
– Fixed CC3+ export setting advanced contours.
– Fixed crash with Expand Land in Offset.
– Fixed crash with climate painting toolbar.
– Fixed some visual elements in dialogs being offset from their ocrrect location.
– Color Key will now update correctly on changes.
– Explicit coastline map feature now available on Advanced export options.
– Fixed crash with odd-sized selection import.
– Prescale offset editing is now on by default.
– What once was large, now is small. World editing preselects are now 1024, 4096, and 8192 instead of 256, 512, 1024.
FT3+ Version 3.5.0
– 64-bit (higher resolutions possible).
– Faster calculation and rendering.
– Uses @FT3Cfg.xml for saving settings.
– Single application look, better matching the OS defaults.
– Better CC3 output (better geometry, better rivers).
– Handles FCW templates better, including sheets and reading compressed templates.
– Added ProFantasy-style normal map calculation.
– Added Equal Earth map projection.
– Color key should better fit its window.
– Globe bar can be resized.
We’ve also added four fast and easy CC3+ export settings that give you a beautiful base to work from in CC3+’s most poular drawing styles.
Excellent news! Thank you very much 😀
Yes!!!! Thank you!!!!
So exciting!
