This is the third part of my series about making an overland map in Campaign Cartographer, you can find the first two parts in earlier posts.
It is now the fun part of making maps start. Up until now we have just created the base for the map, now it is time to populate it and give it life. The first thing I do at this stage is to try to find spots in the map where there supposedly would have been cities or towns if this was the real world. Since it is a fantasy map we’re making we have to remember that the fastest way to travel before modern times is usually by water, so a lot of the cities will be situated along rivers or coasts. In the first picture you can see red circles where I want to place the first cities/towns in the map.
I’ve also marked out some red squares where the map is rather empty, those places we have to work on to make them more interesting, probably adding in something that will trigger the viewer’s imagination and make the map interesting to look at. An empty green field wont draw any attention to it, and with too many places like that in the map the end result wont trigger the imagination of the viewer.
When I’ve placed the first towns I start drawing roads between them. When the roads are in place it is easier to find new spots for more towns or villages. For example if you get a place where two roads cross each other that would be a perfect spot for a new settlement. Other good spots for settlements are next to rivers that the road will cross or next to a mountain, places where it will be natural for people to settle. Places where they can find work or trade.
Usually I divide the map into maybe three or four parts that I work on one at a time. In this way I can see the progress of the map, and it is also more fun when you can see parts of the end result early, makes it easier to keep up the work.
After you are done with the settlements it is time to take a look at those empty areas. Start by adding in some hills, or smaller mountains, add trees and other natural objects like cliffs, caves and farmland. The important thing here is to get more details in the map. At this stage I also add in things like maybe a wizard’s tower, a nomad’s camp or barbarian village. Places for adventures, places where your players would want to go.
A good thing here is also to add new SHEET’s if needed. I for example added a SHEET for the fields because I wanted to adjust the effect on the fields texture that was different from the default one.
Whenever I make a map I always try to have a story in my head. Where is the border between the two kingdoms, are they friendly, if not maybe there should be some fortress at the border? Why is that city so far from all the others, maybe that is a free city where people go for trade, maybe they run a big slave market. Keep asking yourself all these questions when you make the map and fill in all the details and hopefully in the end you will have a great looking map with interesting details that your viewers will love to look at, and that will make them want to go places and having an adventure.
Next step would be to draw the borders between the kingdoms (I actually did this in Photoshop because I wanted a more hand drawn feeling to them) and adding text to cities, towns, kingdoms, rivers etc.
And remember keep up the mapping and good luck.
Excellent advice! Thank you very much for all your hard work 🙂
Series clipped and saved to OneNote. Thanks! 😀
