Command Spotlight – Lines styles and properties
This time I tackle the issue of getting your lines to look the same when you export your map as they look inside CC3+. Why can grid lines sometimes almost disappear in the export? Why is the pattern of dashed lines so different?
All these issues relate to how you scale different things in CC3+. Sometimes the default options are fine, but sometimes they are not what you need for the current map. The intention with this article is to make you aware of these issues, and therefore being better able to both know what to do, but also to make more informed decisions in the first place.
This is tackled in the first Command Spotlight issue, found in the ProFantasy Community Forum.
Comments are closed.
