CC3+ Update 14
Ongoing development and bug-fixing for CC3+ has resulted in plenty of material that we are making available with Update 14 for CC3+. You can download it from your registration page. Try out the new Symbols in Area command and see the the long list of updates and changes:
Command comparisonCC3+ Version 3.80
– Added SYMFILL, SYMFILLM, SYMFILLOPT, SYMFILLLOAD, and SYMFILLSAVE commands as analogs to the ESC* commands for 2D elements. This feature allows creation of map features analogous to those generated by the FOREST tool, but with frilled edges and sparsely-placed internal symbols.
– Added SYMSORT option to FOREST to provide an option to make the output a little cleaner-looking.
– Added ESCM, ESCOPT, ESCLOAD, and ESCSAVE commands to allow use of ESC in drawing tools in a manner similar to FOREST and to create libraries of ESC options.
– ESC can now use the width of symbols as the distance to place them apart.
– Added MKDIR command to allow creating a directory from a macro.
– Modified bitmap options dialog to support display of dpi and resolution information.
– Updated system so that all list boxes (including owner-draw ones) will use the operating system listbox drawing color rather than color 16 (which gets to be a light gray on Windows 10) or the previous value of color 20 (which can be modified by users).
– Added GETGXRETCODE command to support accepting default values in macros
– Added ZOOMSEL and ZOOMSELM commands to allow zooming to the currently-selected entities.
– Added SETFLATTOOLBARS command to allow setting flat toolbar styles from the command line.
– Added GETVIEWL, GETVIEWW, GETVIEWX, and GETVIEWY macro commands to allow getting the current view window from macros.
– Added GETSELL, GETSELW, GETSELX, and GETSELY macro commands to allow getting the current selection extents from macros.
– Added GETDISTFMT to allow saving the DISTFMT state. This command simplifies use of the GET family of commands by allowing the units formatting to be changed and restored.
– Added PSCALESETUP, PSCALEON, PSCALEOFF, and PSCALEX commands to allow for pseudo-perspective scaling of symbols and entities.
– Added SIMPLIFY command to allow simplifying paths to a specific feature size.
– Added support for mouse scroll wheel on symbol catalog and LIST (i.e. text) windows.
– Added “Save to clipboard” operation to text windows.
– Fixed bug that was preventing regular scrolling from using the thumbwheel in text windows.
– Fixed a memory leak in drawing filled multipoly with many nodes that was causing some complex FT drawings to crash CC3 in a matter of a few redraws (e.g. panning the screen for a few seconds).
– Fixed dpi issues in CCL and GLS dialogs as part of the perpetual dpi-related cleanup.
– Fixed system hang when window size reduced to zero height.
– Fixed system crash when drawing area window is minimized.
– Fixed problem where final partial row of symbol catalog would not draw.
– Fixed GOSHEET command to match behavior of SNEXT and SPREV commands.
– Fixed missing COASTLINE sheet in CC3 standard overland template.
– Changed CC3 standard overland style coastline to solid fill to avoid pixelation error
– Fixed Perspectives House Outlines not show on startup
– Fixed Floor fill style selection in PEROPTB (Advanced) not updating preview)
– Fixed problem with IPROJ not working with entities freshly-drawn from a drawing tool
– Fixed problem with EFFECTSCACHE showing wrong sizes on 64-bit Windows.
– Fixed problem where using a space character in FRX settings names would cause XML parser failure and CC3+ collapse at startup. System now correctly sanitizes FRX names so that they are valid XML tag names. – Fixed CC2 references in labels such as Open dialog filters to read CC3+.
– Fixed problem where IPROJ was changing entity color to unexpected value when shaded polygon option was used.
Comments are closed.
