Annual 2022 – May: Electronic Systems
TCA185 Exploration Basehe May issue of the Cartographer’s Annual is now available. It allows you to create an architecture layout of a computer network (or similar), either as a stand-alone map or an overlay on an existing drawing. Add a computer network to a research installation to create a new attack vector for your cyberpunk hacker, or to the enemy starship for your sensor and electronic expert to contend with.
The Annual issue provides both a full template wizard to create these maps from scratch as well as a drawing part to import into any existing map as an overlay. The mapping guide takes you through the slightly more elaborate process of adding the overlay.
The May issue is now available for all subscribers from their registration page. If you haven’t subscribed to the Annual 2022 yet, you can do so here.
Comments are closed.
