All the Annuals: Renaissance City (July 2019)
[Download the FCW file of “Ancient Rome” example map.]
Cities. Not being a fan of mapping cities, I will admit I wasn’t looking forward to another one. Laying out a city is mostly my issue, so for this map I decided to use a cheat – I decided to loosely trace over an existing map – one where I wouldn’t be infringing upon copyrights. Enter a lovely map of ancient Rome I came across is my many hours of just searching through the internet for old maps. Come on, you know you other cartographers out there do it, too! I had come across this map I had found and it really reminded me of the style of Pär Lindström’s Renaissance City Annual, so I decided I would trace it.
After importing the .png into my map using Draw>Insert File and placing it on a new sheet, then applying a transparency to it, I began tracing out my roads first. Once I had my roads placed, I set about placing buildings, rather haphazardly, as I wanted it to look unfinished in some areas, unkempt or sparse than a regularly crowded Renaissance city.
On this map, once again, I applied some of my favorite effects such as Texturize, RGB Matrix and Hue/Sat Adjustment to give it a more antiqued look and my own personal choice of palettes tend to be more muted hues. Once I was satisfied with my placement of buildings, vegetation, etc. I set about adding any little “extras”, etc. On more than one occasion I had to use the SYMSORT command, which sorts out the symbols you choose on a sheet, setting them in proper back to front order if they are layered over each other within the same sheet, as my ADD gets the best of me when mapping anything isometric in nature.
All in all, this was a relatively easy set to work with. I like the clean lines and style of this Annual and I could actually see myself using it again for my own campaign.
About the author: Lorelei was my very first D&D character I created more years back than i’d like to remember. When I decided to venture into creating maps for my and others rpgs, I thought I owed it to her to name myself Lorelei Cartography, since it was her that led me to the wonderful world of tabletop gaming in the first place. Since then I have been honored to have worked with companies such as WizKids, Pelgrane Press, and ProFantasy.
Comments are closed.
