I’ve been mapping with the software for about around 5 years, so rather than follow the tutorial, I figure I’d just supply an overland map using the Mike Schley Overland style in my personal style.
[Download the FCW file]
First, after deciding I would do a smaller environs map of a valley, I quickly established I would do a map set in the season of autumn. I had done a commission some time back for Pelgrane Press, Shards of the Broken Sky, and did a small regional map where I had adjusted the hues in the map for place with red, clay colored soil. That map is so simple, yet one of my favorites I’ve ever done, and it’s all because of the palette. So, for this map, I decided I would do the same in picking autumn.
Since this is a smaller regional map, I wanted to do a wide more natural looking river by separating the landmass on either side with it’s own poly. Normally, I would use the Color Key effect for this, but since I’ve made changes to the Hue and added an RGB Matrix to the Land Sheet, the Color Key will not work, as I am yet to figure out so far, as it cannot adjust your color to the effects on the sheet.
As my usual suggestion, chose the varicolored symbols so you can go back later, if you want, and change this map simply by changing the symbol colors, to a different season. When creating my mountainscape of the valley, I soon realized I wanted more muted leaf colors for my palette and began altering the colors by using the Define Color option, where you can then create your own custom colors. After creating a custom color you should then save and attach it to your map. This can be done by going to the Drawing Properties tab or following File>Drawing Properties and click the attach to drawing tab under Custom Palette. Be sure to do this last step or when you close your map and reopen, it will revert back to the default palette for that style.
Once I had my custom palette set, I am able to place my symbols down, starting with mountains first and using the various shades I created for my autumn them = this gives the mountains, in my opinion, the illusion of them being covered with multicolored trees and grasses in lovely greens, oranges, yellows and reds. Then I do the same for forests, using individual trees or the smaller groups of trees in varying colors, landmarks and finally settlements.
Labeling has always been an issue for me….i just can’t ever seem to be happy with how I label my maps (which is why I am so very excited for Sue’s annual with banners coming up in 2021) – but, since I was going for a fall theme, I decided to stick with the same hues for labels, as well.
So, here’s my version of the Overland Tutorial annual, hope you like it and can use it or alter it for you own mapping needs 😊
