Hot dog! Here is a map I love to make, Dungeons. This map was a quick and easy map I whipped up using the Dungeon Walls Annual in the SS2 style, one of my favorites. I’ve used this style before so I didn’t need the mapping guide, but if you’ve never used it, follow the guide along once and you’ll be all set on how to use Symbols Along and get your walls done.
(Download the FCW File)
As usual, I’ve made some Hue/Sat adjustments to some sheets. And the only other thing I’ve done different is added a wall shadow sheet. Depending on how a set up a map, I sometimes do an inner glow on the floor sheet, but with multiple rooms it gets a bit tedious doing a separate sheet for each floor so each room gets a glow. Or, you can put an outer glow on a wall sheet, rather than the wall shadow. For this map, however, I left the wall shadow set on the wall sheet and then created smaller shadows on the other walls on their own separate sheet.
The map is set up to be printed up in poster size 36×24 – map size of 180’x120’ – and in order to do that you really need to emphasize the grid, or it doesn’t print up well in poster size. For this, I just add a nice strong outer glow on it in the same color as the grid itself. That is just enough to be seen printed out and not have to change the line width of the grid. Or you can hide the grid, for VTT play, like I have been doing during quarantine when we were playing online by using the grid in your VTT platform of choice. Just set up your map size to match this one and it will line up perfectly.
About the author: Lorelei was my very first D&D character I created more years back than i’d like to remember. When I decided to venture into creating maps for my and others rpgs, I thought I owed it to her to name myself Lorelei Cartography, since it was her that led me to the wonderful world of tabletop gaming in the first place. Since then I have been honored to have worked with companies such as WizKids, Pelgrane Press, and ProFantasy.
