A new version of CC3+ is available now, adding full GUI access for more button sizes, as well as better custom palette handling, bitmap tracing, fractalizing and house symbol mirroring. Also a few smaller bugs where fixed.
Version Notes
CC3+ Version 3.91
– Added PALLOAD and PALSAVE commands to load and save different custom palettes.
– Added GUI option (Screentools button) to allow user to pick any of the 4 available icon resolutions instead of just large/small.
– Added a TRACE and TRACED command to trace around a bitmap in a more general way than the CONTOURSM family of commands.
– Modified Fractalize (FRX) command to affect outlines even if they are separate entities.
– Modified roof shading code to flip angles by 180 degrees when specifying mirrored on bitmaps
– Fixed blur radius computation in effects when using Map Units.
– Fixed lighting direction on mirrored symbols (initial implementation in June was incorrect).
– When the system issues a “no matching drawing tool” message, will now show the tool name that it was looking for.
– Cosmographer 3 deckplan bitmap templates can now add new grids?
– Fixed bug in FastCAD core that was preventing higher-resolution icon sets from loading.
– Fixed crash on exit when writing XML file that was intermittently appearing as project changed.
Download this latest update from your registration page.
